2000 Jeep Cherokee
PROFITSON
  • 2000 JEEP CHEROKEE
Engine Cooling problem
2000 Jeep Cherokee 6 cyl Two Wheel Drive Automatic
this jeep over heating I chang a thromstat and ran a compression check on all cyclinger and the ran 150 or more but I havent chang the water pump yet why is it over heating it take a while for it to overheat like 30 minutes
Monday, September 6th, 2010 AT 10:28 AM
WRENCHTECH
  • 20,761 POSTS
Are you losing any coolant over time?
Monday, September 6th, 2010 AT 10:50 AM
PROFITSON
  • 12 POSTS
No where its acking like its coming back threw the radi
Monday, September 6th, 2010 AT 11:04 AM
WRENCHTECH
  • 20,761 POSTS
You could have any number of things wrong and a blown head gasket is one of them. A clogged radiator or bad water pump are also possible. You probably should have some chemical tests with an exhaust analyzer done on the coolant to determine if you have a bad head gasket or not.
Monday, September 6th, 2010 AT 11:08 AM
