1999 Jeep Cherokee will crank but won't catch without a lit
PJAMES9
  • 1999 JEEP CHEROKEE
  • 6 CYL
  • 4WD
  • 124,000 MILES
If anyone could help me I would so appreciative! I ahve a 99 jeep chk. Sport. I have put some work into over the years and for the most part it runs fine. But when it gets cold out sometimes turning the key won't start the engine. I have to give it some gas and then slowly back off the accelerater until it "catches". Any clue as to what it could be? I started noticing the problem the same time that my front left headlight dimmed to half power as well as my turn fog lights (replaced the bulbs- they were not the issue). Also the passenger side power window goes in and out. I'm sure that the problem is electrical having check most everything else. Any advice would be greatly appreciated! Thanks for your time!
Thursday, October 15th, 2009 AT 9:34 PM
CJ MEDEVAC
  • 11,005 POSTS
Passing along info. Seems that your rig has history or wires CUT or Broken, in the area between Driver door and body.
Thursday, October 15th, 2009 AT 11:24 PM
PJAMES9
Thanks for the info brother- i'll try it and see if that is indeed the issue i'm having! Appreciate the time
Friday, October 16th, 2009 AT 5:32 PM
