Car won't start. All lights, dash and car alarm work.
Replaced ignition switch - nothing. Had solenoid tested, tested good. Replaced relay - nothing. Any other recommendations?
Saturday, September 18th, 2010 AT 5:49 PM
CJ MEDEVAC
MECHANIC
See my profile
Did you remove the starter and have it tested?
Remove clean and tighten EVERY Mechanical Joint in your system (Battery clamps to their cables too)? Negative Ground to Engine and Frame Also!
Leave no connection aloneNo "It looks Good"DO IT ANYWAY!
The Medic
SPONSORED LINKS
Saturday, September 18th, 2010 AT 8:15 PM
RHERN
MEMBER
We had starter tested, they said it was good. Took it to new place and had it tested, they said it was not good. Bought a new one, installed, car is back on the road!
Thanks for all of your suggestions though.
Saturday, September 18th, 2010 AT 9:36 PM
CJ MEDEVAC
MECHANIC
AIRBORNE!
The "ONLY Time" a Jeep Hood should be up, is to SHOW-OFF your AWESOME POWER-PLANT!
