A few days ago the transmission overdrive suddenly jumped out and into the next lower drive range. It does'nt matter if I shift into OD using the shift button after I start driving or if I have the OD shift button already ingaged when I start out. This problem started with no warning signs. The previous day everything shifted normally. I am competent in a wide area of mechanical repairs, but know very little about automatic transmissions. Your help will be greatly appreceated.Thank you.
Sep 11, 2009 at 2:13 PM
