1998 Jeep Cherokee truck won't stay crank
LANEHART C
  • 1998 JEEP CHEROKEE
  • V8
  • 4WD
  • 233,126 MILES
My truck won't turn over
Thursday, April 15th, 2010 AT 12:54 PM
If its cranking over and will not start do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Thursday, April 15th, 2010 AT 1:10 PM
