1998 Jeep Cherokee Car goes dead
PRINTER2000
  • 1998 JEEP CHEROKEE
  • 6 CYL
  • 150,000 MILES
My 1998 Jeep Grand Cherokee will go dead while it's running and won't crank up for a long time.
Thanks, Tom
Thursday, December 31st, 2009 AT 12:48 PM
Check what's missing fuel or spark? Do below, don't wait.
Cranks and w/n start
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Friday, January 1st, 2010 AT 6:35 AM
HUSQVARNAUSA
  • 14 POSTS
Check your spark and see if your alt is good and your batt. Also
Tuesday, February 9th, 2010 AT 11:24 PM
