Is some fuel supposed to stay in the line so that upon next startup, the engine gets fuel quickly? I find that if the engine has been off for more than one hour, it requires a lot of cranking to get it started. The battery is new and spins the engine very fast. Sometimes I have to "give it gas" when cranking, like older cars, in order to start (don't want to crank it longer than 5 seconds). If the engine has been off less than an hour, it starts "instantly" without problems. Might there be a small leak in the fuel line, or the check valve (if any) is allowing the fuel to drain back into the tank, so that it takes awhile to feed the engine, after it has been off for a longer period.
Jun 22, 2009 at 1:27 PM
