1998 Jeep Cherokee oil pressure
1998 JEEP CHEROKEE
146,000 MILES • V8 • 2WD • AUTOMATIC
CWHAYES67
im driving down the road, at normal speeds, when all of a sudden my oil pressure drops to 0, i shut off the engine, and started it back up, and the pressure comes up to about 40 psi, this has happened to me numerous times, one thing i do know is the rear main seal is going bad and needs replacing soon, but what could cause a crazy situation like oil pressure dropping to 0
Jan 9, 2008 at 6:41 AM
BMRFIXIT
  • 19,053 POSTS
[quote:636cc71411="cwhayes67"]Engine problem
1998 Jeep Cherokee V8 Two Wheel Drive Automatic 146000 miles
im driving down the road, at normal speeds, when all of a sudden my oil pressure drops to 0, i shut off the engine, and started it back up, and the pressure comes up to about 40 psi, this has happened to me numerous times, one thing i do know is the rear main seal is going bad and needs replacing soon, but what could cause a crazy situation like oil pressure dropping to 0[/quote:636cc71411]
if oil level is OK
change the oil pressure switch
get it from the dealer
I replaced it three times from after market
worked for a day or two
get it from dealer its going on its 7 month
not much of a price difference
let me know
good luck
Jan 11, 2008 at 1:13 PM
