1998 Jeep Cherokee cranks but wont start when its cold
VIC46
  • 1998 JEEP CHEROKEE
  • 6 CYL
  • 119,000 MILES
I have a 98 cherokee that cranks but does not start if its real cold outside could this be the came shaft sensor and if it is where is it located and is it easy to replace could you please send me some kind of diagram so I can see what it loos like and how I can replace it
Thanks
Victor Vargas
Sunday, March 29th, 2009 AT 11:12 PM
BLACKOP555
  • 10,371 POSTS
Sounds to me like a bad coolant temperature senosr. Replacing it should fix teh problem.
Tuesday, December 17th, 2019 AT 7:08 PM
Have a 98 cherokee that cranks but does not start
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Could be the CTS not telling the computer to enrich the A/F mix during initial start up.
