1998 Jeep Cherokee cranks but wont start
SHEA 13
  • 1998 JEEP CHEROKEE
  • 6 CYL
  • 135,000 MILES
My jeep had trouble starting, but eventually did and ran great. Then stopped starting. I replaced the starter that did nothing. Then replaced the crank sensor, and that seemed to fix the problem for a week. Noe its just cranking but not starting. Like before I changed the cps.
Sunday, October 10th, 2010 AT 2:43 PM
JDL
  • 16,098 POSTS
When the problem occurs have a helper crank it, while you visually check for spark at the plugs. If no spark, check primary voltage to the coil, engine cranking, dark green wire with orange tracer. Also, check for voltage at the same color wire at injectors. If no voltage, engine cranking, the computer may not be grounding the asd relay for some reason, maybe cam and or crank sensor. Can you check trouble codes? There could be other issues with the relay, wiring circuits? Any suspected sensor issues, check the wiring circuits, first.
Tuesday, December 17th, 2019 AT 7:09 PM
