1997 Jeep Cherokee wont fire
JAKE T
  • 1997 JEEP CHEROKEE
  • 6 CYL
  • 4WD
  • 170,000 MILES
Will start while spraying starter fluid in it wondering where the fuel pump is located and how to check if its working I can hear it humming when the key is turned
Tuesday, August 17th, 2010 AT 7:44 AM
JDL
  • 16,098 POSTS
Use a gage and check for proper fuel pressure. Some of the national brand autostores used to loan out a fuel pressure gage, if you don't have one. How long since the fuel filter was changed? As far as the filter make sure there is no pressure on the system before taking any lines loose. You might also use a noid lite and check for injector pulse. Any applicable trouble codes?
Tuesday, August 17th, 2010 AT 10:13 AM
