Throttle positon sensor signal is also use as an indication of the transmission throttle pressure to the computer-
Some vehicles the coolant temperature sensor is use as input signal to the computer to command overdrive-in a given temperature-
Did you check the circuit back to the computer for an open or short to ground.
SPONSORED LINKS
Saturday, May 24th, 2008 AT 11:18 AM
