Idle speed
160,000 MILES • 4.0L • 6 CYL • 2WD • AUTOMATIC
POPRIK
Installed New TPS, need idle speed.
Sep 3, 2016 at 5:12 AM
WRENCHTECH
  • 20,760 POSTS
I don't know what you are asking. The idle speed is not adjustable.
Sep 3, 2016 at 9:59 AM
POPRIK
I've adjusted idle down from 1000 rpm to 750. Need to know what the idle rpm should be? TKS, POPRIK
Sep 4, 2016 at 1:40 PM
WRENCHTECH
  • 20,760 POSTS
No, you didn't adjust the idle speed. You messed with the idle stop and you should not have done that. The computer controls the idle speed by metering air through the IAC.
If the idle speed was too high, then there is likely an air leak somewhere.
Now you have to not only find the base problem but then re-calibrate the idle stop screw.
Sep 4, 2016 at 8:56 PM
