HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Jeep
Cherokee
Engine
Symptoms
Not Running
SPONSORED LINKS
1997 Jeep Cherokee It wont start
BOXER79
MEMBER
1997 JEEP CHEROKEE
Electrical problem
1997 Jeep Cherokee 6 cyl Four Wheel Drive Automatic
I turn the key to start and there is like nothing the sarter don't kick on to start all the key dose is it makes a clicking sound in the fuse panale
Saturday, June 14th, 2008 AT 12:18 AM
BLACKOP555
MECHANIC
Sounds like hte battery is dead/very weak, or the terminals/cables are corroded and need cleaning.
That should fix you fright up!
If still noting it is probably a bad starter relay/olenoid or maybe a bad starter.
Check the first two first.
SPONSORED LINKS
Saturday, June 14th, 2008 AT 5:50 PM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
1997 Jeep Cherokee Car Will Not Start - Sometimes
My Daughters Jeep Will Start Sometimes And Sometimes It Will Not. He Husband Has Replaced The Ignition Switch On The Steering Column....
Asked by
rp-dakota02
1997
JEEP CHEROKEE
VIDEO
How to fix an engine that wont start
Instructional repair video
GUIDE
Engine Not Starting
Over the past 20 years at 2CarPros we have identified the top problems that are easily fixed. This guide can save you a trip to the repair garage or calling a tow truck and...
1997 Jeep Cherokee Car Wont Start
Engine Problem 1997 Jeep Cherokee 6 Cyl Wheel Drive Type Unknown Automatic 98000 Miles My Car Had Been Dying Recently While I Drove...
Asked by
jjcoombs123
1 ANSWER
1997
JEEP CHEROKEE
1997 Jeep Cherokee Will Not Start
1997 Jeep Cherokee 6 Cyl, Standard, Won't Start. It Has Been Having This Problem Periodically. It Will Start Right Up, No Problems. I...
Asked by
Jonwyn
1 IMAGE
1997
JEEP CHEROKEE
Hi - This Car Has Sat Unused For A Few Weeks Here In Yuma Az. There Was Nothing Wrong With It When Parked. When I Went To Start It, The...
Asked by
Gunny M
1997
JEEP CHEROKEE
1997 Jeep Cherokee Car Won't Start
Yesterday, My Car Started, But My Wipers (front And Rear), Interior Fan, Radio, And Turn Signal Would Not Work. The Headlight Worked...
Asked by
ljwalsh
1 ANSWER
1997
JEEP CHEROKEE
VIEW MORE
SPONSORED LINKS
Crankshaft Sensor Replacement
Crankshaft Sensor Symptoms
Online car repair manuals
