1996 Jeep Cherokee Air Coditioning noise upon acceleration
SHALOMP
Noises problem
1996 Jeep Cherokee Four Wheel Drive Automatic 101000 miles
Whenmy air conditioning/defrost is turned off, I have no problem. However, whenever either my A/C or defrost is on I have a problem. When I am idle everything is fine, A/C works great.
But whenever I ACCELERATE, push on the gas, and only when my A/C is on I get this loud sreeching noise from under the hood. When I shut A/C the sound stops immediately. Also stops if I take my foot off of the gas pedal!!
Jun 15, 2008 at 4:11 PM
TV8BIRD
  • 10 POSTS
Time for a serpentine belt.
Your old one is worn out. As you accelerate, you're putting tension on it. When the A/C is on, there's even more tension. Switch the belt, you should be fine.
Tensioner is a bolt at the right side of the engine.
Jul 29, 2008 at 12:21 AM
BAKEDFLOUNDER
Did you ever find out what the answer to the Jeep noise was? I have the same exact car, with the same exact problem.
Please reply, Thanks
Aug 8, 2008 at 11:45 AM
