1996 Jeep Cherokee Hard Restart
JUSTIN_BUR2000
I think my starter is bad. 1st how much does a starter run. 2nd were is it located under the hood.
I start the jeep get to my location and have a hard time restarting it sometimes doesnt even start back up. anyting will help
Aug 13, 2007 at 12:49 PM
TURBINEMAN33
  • 5 POSTS
first you can have a starter rebuilt for about 40-50 dollars second the starter is located under the motor follow the wire from the battery
Aug 14, 2007 at 5:05 PM
DPWD23
  • 136 POSTS
Starter is on the passenger side of the engine.
If you are confident you can replace it yourself, you could save time and get a lifetime warranty if you buy a rebuilt unit from certian auto parts stores. They will charge a core fee, meaning you have to take your old one back to get a portion of the money back.
I would recomend getting the old one off and taking it in for testing. The machine at the auto parts store will test it several times not just once, and some modern testing machines test the crap out of them to make sure it won't miss a problem.
Now, if you don't know what you are doing, I would recomend buying a repair manual. They have Chiltons and Haynes at most auto parts stores. I prefer the Chilton's but others prefer the Haynes. Their is also a link on the main page of this site to purchase repair manuals. The information in one of these will save hours of frustration trying to figure out how to get parts off, or replaced, as some are trickey.
Aug 17, 2007 at 6:27 PM
Suggested Repair
The starter is on the passenger side of the engine; follow the battery cable to locate it. Remove it and have an auto parts store test it repeatedly. If it fails, install a rebuilt starter (core charge applies; some stores offer a lifetime warranty). Use a Chilton or Haynes manual if you are not comfortable doing the job.
Conversation Summary
The owner of a 1996 Jeep Cherokee has trouble restarting after driving and suspects a bad starter, asking about cost and location. A reply said a rebuild can cost about $40–$50 and to follow the battery wire under the engine. The expert said the starter is on the passenger side, recommended removing it for thorough parts-store testing, and suggested a rebuilt unit with a core charge and warranty, plus a repair manual for DIY work.
