1989 Jeep Cherokee Starter motor
P. HEINZE
  • 1989 JEEP CHEROKEE
Engine Mechanical problem
1989 Jeep Cherokee 6 cyl Two Wheel Drive Automatic 200K miles
Starter motor will not engage flywheel. Makes stacato noise when ignition turned on. New battery, new starter motor. Electrical hook ups are correct. Stumped.
Friday, December 26th, 2008 AT 10:27 AM
2CARPRO JACK
  • 11,533 POSTS
Im not sure what a stacato noise is, but you may need to inspect the flexplate (flywheel) to be sure the teeth are all intact. Also test for full 12 volts down at the starter on both the main cable and the trigger (small) wire. Does the starter try to turn when key is on but not in crank position? If so be sure the small wire isnt touching the main cable at the starter motor. Also might want to count th enumber of teeth on the new and old starters to be sure they are the same
Friday, December 26th, 2008 AT 12:56 PM
