1995 Jeep Cherokee question
DAVECRAZE
  • 5 POSTS
Transmission problem
1995 Jeep Cherokee 6 cyl Four Wheel Drive Automatic
hi dave here i have a 95 jeep cherokee and the transmission makes noise like a whine and i cant get it over 50 ks i dont know if i need a new tranny or is it a fix i can do in my garage
Apr 3, 2009 at 12:57 PM
  • 110,248 POSTS
Dan:
A whining can be many things so I can't give you a definite answer. Is it shifting, slipping... Is the fluid burnt?
Apr 7, 2009 at 1:21 PM
DAVECRAZE
  • 5 POSTS
its not slipping and it shifts into gears fine it just wont go over 50 and it whines while in park and u dont hear as much noise while driving its a grand cherokee laredo ive tried to find trannys but no luck
Apr 7, 2009 at 2:50 PM
  • 110,248 POSTS
The noise may be coming from the converter. However, if the trans doesn't slip and it shifts properly, are you sure the engine isn't causing the 50MPH limit?
Apr 8, 2009 at 3:36 AM
DAVECRAZE
  • 5 POSTS
the exhaust sounds a little funny like a whistle or like a turbo would sound like because it gets to 50 fast but then cant get any faster the tranny shifts good i would say almost like its gonna hesitate without the jerking
Apr 8, 2009 at 4:37 AM
  • 110,248 POSTS
I want you to check something. Everything you have described sounds like the catylatic converter is plugged. I will kill engine power. Check for back pressure from the exhaust. Listen for whisteling or ratteling from the converter area. Also, if you can, disconnect it to see if it runs any better.
I can't be sure, but now that you described the turbo like sound, that is what I'm thinking. I can't think of anything in the trans that would stop you at 50mph. Especially if it is shifting good, not slipping...
Apr 8, 2009 at 6:31 AM
DAVECRAZE
  • 5 POSTS
their is very little pressure from the tail pipe the exhaust is new as well
Apr 8, 2009 at 8:49 AM
  • 110,248 POSTS
Is the converter new? There should be a good bit of back pressure.
Apr 8, 2009 at 10:21 AM
DAVECRAZE
  • 5 POSTS
yes the converter is new but back pressure is very little the muffler is new as well the exhaust is about 1 3/4 diameter doesnt look like two inch at all the whine seems to come out of the exhaust i think thats where it sounds like its coming from
Apr 8, 2009 at 1:30 PM
