1995 Jeep Cherokee Tea Kettle Squeaking Noise
1995 JEEP CHEROKEE
158,000 MILES • 6 CYL • 4WD • AUTOMATIC
JBLYTHE0204
I have a '95 Jeep Cherokee with 158,000 miles and on De-acceleration there is a high pitched tea kettle or kazoo type noise. it almost sounds like bad brakes but i don't think its that. Any Ideas?
Dec 19, 2008 at 8:33 AM
ANIMALFARM
  • 58 POSTS
Immediate thought is hole/crack in a vacuum line. Any other noteable performance issues to go along woth the noise? Does the noise ONLY occur when brakes applied, or always there regardless? Does the pitch of the noise change as engine speed slows? Does the noise appear only when brakes are NOT used?
The noise is similar to what you would hear if you blew up a balloon, then pulled the end flat across and let the air out? You know - Squeee, squeee, squeee...?
Dec 19, 2008 at 9:11 AM
JBLYTHE0204
it happens on acceleration too. and then stops when i reach 30mph. so im almost positive it's not the brakes. but it almost sounds like somethings rotating with the squeak. i have a small oil leak but it has had that since i bought it.
Dec 19, 2008 at 10:38 AM
ANIMALFARM
  • 58 POSTS
I believe you just provided the clues... When you speed up, when you let off gas to slow down, ROTATING, Hmmm... You have a loose belt, or perhaps a bearing in one of the belt-driven items. Try tightening belt, see what happens. Hmmm... Or are you SURE it's not the belt as you would recognize that sound?
Dec 19, 2008 at 11:32 AM
JBLYTHE0204
haha yea i know i was thinking it was that, but just wasnt sure. the belt is tight but looks a little glossy. i have no clue when the last time it was changed.
Dec 19, 2008 at 12:25 PM
JBLYTHE0204
Thank you for replying by the way.
Dec 19, 2008 at 12:27 PM
ANIMALFARM
  • 58 POSTS
No problem-o...This is actually fun. I have questions that I need answers to, also, and I require other opinions to confirm/deny my train of thought. If it's a FIX, post back...Others will see if they have similar probem.
Dec 20, 2008 at 12:59 AM
