1995 Jeep Cherokee hard to start, takes long time even long
1995 JEEP CHEROKEE
162,000 MILES • 6 CYL • 4WD • MANUAL
95 JEEPXJ
When I turn the key on to start, a ticking noise comes from the relay box ( fuel pump relay) when done ticking fuel pump comes on. When it's average temp. outside 15-30 minutes when cold out 20-40 degrees up to 2 hours. After fuel pump comes on has to prime,( if you would) another 15 minutes until it will start and stay runnin. If it's off for 20 minutes or more I have to go through the whole process again. I've replaced the fuel pump, filter, relay, pressure regulator and a complete tuneup and crank sensor. Always has good fuel pressure, that's why I think it's an electrical issue. Any help is much appreciated.This is one Jeep thing I don't understand. Thanks, Jonathan
Mar 2, 2010 at 7:39 PM
  • CERTIFIED EXPERT
  • 110,175 POSTS
When it won't start, check to see if it is getting both spark and fuel to the engine?
Mar 4, 2010 at 8:23 AM
95 JEEPXJ
it is, i got a computer from the salvage yard yesterday and found out, even though my was rebuilt, it was bad or going out, this one fixed it. Thanks for the reply though.
Mar 4, 2010 at 8:27 AM
  • CERTIFIED EXPERT
  • 110,175 POSTS
That post was from 2010, so chances are there won't be a reply. However, in the final post, the person indicated the PCM took care of the problem.
Is your vehicle the same year, make, and model? Let me know. If it is, let me know exactly what you are experiencing.
Dec 25, 2022 at 6:48 PM
