1995 Jeep Cherokee accerlations
ZIKA86
  • 1995 JEEP CHEROKEE
  • 6 CYL
  • 184,059 MILES
When I starts the the jeep it starts up fine until I start driving while pressing the gas peddle a few second later the accelerating slows down while my foot is on gas later the jeep starts accelerating on time again and sometimes it does that problem when im making a left or right turn. What do I need to repair with this problem?
Saturday, January 16th, 2010 AT 6:25 PM
Check and test the following below
Oxygen sensor
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Cap and Rotor
Saturday, January 16th, 2010 AT 7:08 PM
