1996 Jeep cheerokee car repair question
WRFOWLER
  • 1996 JEEP CHEROKEE
I am having problems with my 1996 jeep cheerokee the only way it will start is to hold the gas pedal to the floor it will just sit there and grind the starter untill I push the gas pedal to the floor. The mileage on this is over 100,000 miles. The size of the engine is 4.0 six cylinder. Hope you can help with this problem.
Friday, July 20th, 2007 AT 4:01 PM
MERLIN2021
  • 17,250 POSTS
Try turning the key to on for 4-5secs. Then off then on again 4-5secs. Do it three or four times. Now see what happens. If it starts ok, check fuel pump pressure. If not start it your way and test pump pressure.
Saturday, July 21st, 2007 AT 2:14 PM
