1993 Jeep Cherokee
JEEP76
  • 1993 JEEP CHEROKEE
I have a 1993 jeep cherokee country 4d, 2wd, and it has 170650 miles, and it is making a wining nosie in the back only at higher speeds like 40 and up but only when I have the gas pedel on please help me figer out what it is?
Sunday, June 4th, 2006 AT 11:27 PM
BENZ_GUY
  • 28 POSTS
Go purchase an inexpensive OBDII code reader. You can get cheap ones for under a $100 dollars at most autoparts stores (or online). It's worth the investment, specially since it will work on most vehicles made from 1996 to 2006.
Or, Autozone will either check it for you for free / or you put down a $$ deposit and use their tester - run outside check the codes - then take it back in and get your deposit/money back.
Once you get the code, post it and we'll try to help more.
Hope this helps
Thursday, April 6th, 2006 AT 12:56 AM
