1994 Jeep Cherokee wont start
DWENDTNJ
  • 1994 JEEP CHEROKEE
  • 6 CYL
  • 4WD
  • 160,000 MILES
The jeep was running fine put it in to have the muffler changed and the catalytic converter, at that point it was still running fine, purchased a new battery and when I changed it the car will not start, the battery is good. The car will crank but not start. Any suggestions would be appreciated
Saturday, May 16th, 2009 AT 7:18 AM
  • 109,747 POSTS
Have you checked for spark and fuel to the engine? Also, make sure the battery cables are in good condition and not corroded. Finally, check the ground from the battery to the engine block to make sure it is clean and tight.
Let me know what you find.
Sunday, May 17th, 2009 AT 2:54 PM
