1994 Jeep Cherokee Won't start
NCOX
  • 1994 JEEP CHEROKEE
  • 6 CYL
  • 4WD
  • 147,563 MILES
I get in and put the key in and turn, but nothing happens and it is a new battery and the altenator is fine so what could it be?
Sunday, January 27th, 2008 AT 2:42 PM
VANQUISH86
If your battery is fine than I would most likely say it 's your starter, but I would first check your spark plugs and your coil since they are also passobilities and are cheaper to replace. This is if your car is just not turning on but you said nothing happens when you turn the key. So if this means that your car is not getting any power what so ever than you should make sure your battery cables are well conected or if they even work at all
Sunday, January 27th, 2008 AT 2:58 PM
