1994 Jeep Cherokee not starting
BADAHLE
  • 1994 JEEP CHEROKEE
  • 6 CYL
  • 4WD
  • 275,000 MILES
The engine is not starting. It will try to start but dies right away. It has good fuel pressure. Some said it could be the iac valve. How do I check this.
Friday, June 26th, 2009 AT 11:48 AM
What was the fuel pressure readings?
Saturday, June 27th, 2009 AT 6:14 AM
BADAHLE
  • 5 POSTS
Yes the fuel pressure is at 39psi when the pump primes, it jumps up when you crank it.
It will chrank and fire for about 2 secs then dies. When giving it gas when giving it gas it might last 3 to 4 secs.
Monday, June 29th, 2009 AT 6:20 AM
Check the delivery of the fuel pump should deliver 1pt of fuel in 30secs
Monday, June 29th, 2009 AT 2:38 PM
BADAHLE
  • 5 POSTS
I checked thefuel delivery it put out 1 pt iin about 20 secs.
I checked the tps it checks alright with the jeep on but not running. When you crank it over all the readings go blank.
When I mess with the throttle it will run slightly.
Tuesday, June 30th, 2009 AT 6:26 PM
Try cleaning out the IACV and see what happens
Tuesday, June 30th, 2009 AT 6:56 PM
BADAHLE
  • 5 POSTS
I put a know one on. Because we thought that was the problum to start with.
Tuesday, June 30th, 2009 AT 9:28 PM
