1994 Jeep Cherokee Jeep cuts out after being run for about
HONABOY
  • 1994 JEEP CHEROKEE
  • 4 CYL
  • 4WD
  • 101,000 MILES
Hi it will drive for about 10 mins then won, t start sometimes starts up after a few mins but not before some times will not start at all I looked up this seems to be a common fault but nobodies saying what the problem is according to the mechanic that looked at it he said the fuel system is ok but he couldn, t get it started so he does, nt inspire confidence alot of peple that have had a simular problem have changed the fuel pump on a number of times tono avail some seem to think it is its the ecu but at $600 its a bit steep if it doesn, t work surley with all the faults that are on this car somebody knows what the problem is and what to test first this is a desperate situation as like most people I haven, t a lot of money and need the car can anybody please point me in the right direction and if it is a common fault if you can let me know I would be very gratfull thanks for reading it is apperiated paul
Tuesday, October 14th, 2008 AT 6:43 PM
JNOVACK
  • 723 POSTS
Check the fuel pressure coils or distributor cap pickup coil if has distibutor Ignition Control Module Solenoid Switch plug wires and plug last the timing
Tuesday, October 14th, 2008 AT 8:11 PM
HONABOY
Hi thanks for getting back I will try these they make sense thanks again
Wednesday, October 15th, 2008 AT 1:58 PM
