1994 Jeep Cherokee ignition switch
BRUDDADAN
  • 1994 JEEP CHEROKEE
  • 6 CYL
  • 125,000 MILES
How do I remove the ignition switch? I removed the steering wheel, horn contacts and turn signal plate. Whats next?
Friday, January 4th, 2008 AT 5:21 PM
BLACKOP555
  • 10,371 POSTS
Remove the ignition tumbler by inserting the key and turning it to the on position. Then insert a straightened paper clip into the hole and depress the button, next pull out on the tumbler, it should come right out. Once its out remove the bezles that hold in the ignition switch and pull it out.
Friday, January 4th, 2008 AT 7:48 PM
