2. Do I need to disconnect the ignition switch rod?
3. Is this model have the thru bolt style key cyl. Or is it retained by a clip; if so, is there a special tool?
4. Also, the key does not turn the ignition anymore. Will this be a problem in the installation or removal of the ignition lock cyl?
SPONSORED LINKS
Friday, January 16th, 2009 AT 5:43 PM
