1994 Jeep Cherokee Check Engine Light comes on & goes o
YORKILUVR
  • 1994 JEEP CHEROKEE
  • 6 CYL
  • 230,000 MILES
I checked the MIL & the codes I got are 10 and 33. I've checked the fluid levels & they're satisfactory. It does use about a quart of oil a month & more with extended driving. I did notice some hesitation last week when I tried to go around a car in traffic & the Jeep bogged down so I had to just ease back into my lane.
yorkiluvr
Thursday, June 10th, 2010 AT 10:22 PM
Dunno where you got 10 but 33 Fault in air conditioning cutout relay circuit.
Using oil -best check if the plugs are fouled-up causing the hesitation and could be one of the following below
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard
Friday, June 11th, 2010 AT 5:53 AM
