1993 Jeep Cherokee Won't start up with key
ASHAD24
  • 1993 JEEP CHEROKEE
Electrical problem
1993 Jeep Cherokee V8 Four Wheel Drive Automatic
My jeep will not start up when you turn the key to on. I already replace the switch. The radio comes on and lights it just want crank up.
Sunday, May 30th, 2010 AT 8:39 PM
OBXAUTOMEDIC
  • 3,711 POSTS
Have you tried jump starting it? If not and you can get someone to help do so. If vehicle starts take to local parts store and have them check Battery.
Sunday, October 20th, 2019 AT 4:25 PM
ASHAD24
You can jumpstart it it wont start with the key. You can start it with the relay switch under the hood.
OBXAUTOMEDIC
  • 3,711 POSTS
Ok, is the relay below the one you are jumping across to start it?
https://www.2carpros.com/images/question_images/199408/original.jpg
Also have you checked Fuse #12 (40 amp) in the Power Distribution Box in the engine compartment on Passenger side.
ASHAD24
No power is going to the switch to start it up.
OBXAUTOMEDIC
  • 3,711 POSTS
Ok, have you checked the fuses in the power distribution box. There are a few for the Starter Curcuit.
Check fuse number 12 it's orange and 40 amp it is on the Run and Start Curcuit also check fuse number 13 it's blue and 60 amp it is on the Start only curcuit.
