1993 Jeep Cherokee V8 Two Wheel Drive Automatic
Getting pressure on fuel line. Replaced starter relay. Using fully charged battery. No security system as far as I can tell. Need diagram on inside fuse panel-cover missing-bottom right fuse/breaker or starter relay?Is getting very hot with nothing turned on. No codes cany even find the hook up port. Getting check engine light and others with key on.I was told that is an indicator the computer is ok. Other electrical systems working ok. Turns over wont start. Help Thanks Russ -russellhamrick@gmail. Com
SPONSORED LINKS
Monday, October 12th, 2009 AT 5:41 PM
