1993 Jeep Cherokee wont start
DANNYM
  • 1993 JEEP CHEROKEE
  • 6 CYL
  • 4WD
  • 190,000 MILES
Got 1993 grand cherokee 190k. Was running fine. Next morning wont start. Alarm is disabling when car unlocked.
just will not kick over. Where do I start?
Sunday, October 12th, 2008 AT 6:19 PM
BMRFIXIT
  • 19,053 POSTS
Check for spark
check for fuel and fuel pressure
suspect crank sensor
check ASD relay
Friday, July 28th, 2017 AT 4:33 PM
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
