1993 Jeep Cherokee transfer case
CLAYANDCRAFT1
  • 1993 JEEP CHEROKEE
  • V8
  • AWD
  • 129,000 MILES
My transfer case is going bad. Last night I was driving home and my engine just lost power and stopped. Jeep will not start now. Could this be the cause.
Wednesday, October 22nd, 2008 AT 3:04 PM
JASONRAY
  • 213 POSTS
I doubt it. Your transfer case only comes into play when you're in 4wd. Check fuel pressure. This could likely be the cause of your engine failure.
Wednesday, October 22nd, 2008 AT 4:55 PM
CLAYANDCRAFT1
The truck is a 1993 grand cherokee laedo and has all wheel drive. Could it still be the fuel pressure. Thank you,
kathy
Friday, October 24th, 2008 AT 7:29 PM
JASONRAY
  • 213 POSTS
Yes, it could. It could also be other things, as well. I've replaced a lot of ignition coils on jeeps, too. However, if that's the case, it won't lose power, it'll just DIE! (Usually) Since you lost power before it just died, I'd be more likely to blame the fuel pressure.
Saturday, October 25th, 2008 AT 12:26 PM
