When you turn the key nothing happens. Battery is in good working condition. This happens intermitantly.
Saturday, January 19th, 2008 AT 12:02 PM
MCQUE
MEMBER
Your Neutral Safety Switch may be dirty, stiicking, or defective.
Wiggle shifter while turning key. Try starting in Neutral instead of Park. Try with slight forward and reverse pressue to shifter. If car thinks you are not clearly in Park or Neutral, it will not try to Start.
