1993 Jeep Cherokee Bypass Altenator
CRAIGWALKER
  • 1993 JEEP CHEROKEE
  • V8
  • 4WD
  • 189,000 MILES
Is there a way to bypass the alternator to get my Jeep started?
Wednesday, July 22nd, 2009 AT 8:19 AM
JDL
  • 16,098 POSTS
Hello, I don't believe your alternator has anything to do with it? Make sure the battery has a full charge and the cables are ok. Then, I would check the circuits at the starter relay, in the power distribution center under the hood. The voltage for the switch side of relay is usually hot all the time. Voltage for the control side of relay should go hot with the key in the crank position. With an automatic, you might try cranking in neutral.
Wednesday, July 22nd, 2009 AT 8:54 AM
