Steering problem
1989 Jeep Cherokee 6 cyl Four Wheel Drive Automatic 221k miles
very bad front end shimmey, seems to be on r. Side.
Tuesday, November 3rd, 2009 AT 3:10 PM
MERLIN2021
MECHANIC
Easiest part to check is the track bar it attaches under the radiator, if the ball end is loose, replace it, and check the mounting hole it bolts into as well. Also check the ball joints, if bad it will wobble at about 45 MPH.
