The engine overheated, I have changed the thermostat (twice), put in new water pump and new radiator. It still overheats. The upper radiator hose does not feel hot after the temp gauge goes over the 210 mark (thermostat is 195). Also, when I add coolant to the bottle, it does not drain out. It will drain after I run the engine for a while. Any advise is appreciated. Thanks.
SPONSORED LINKS
Thursday, August 7th, 2008 AT 2:20 PM
