HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Jeep
Cherokee
Fuel System
Fuel Pump
Replace/Remove
SPONSORED LINKS
1988 Jeep Cherokee fule system
KIRT1987
MEMBER
1988 JEEP CHEROKEE
Engine Mechanical problem
1988 Jeep Cherokee 6 cyl Four Wheel Drive Automatic
i recently had problems with the fule presher so I replaced my fule pump but it has not improved any what else could cause the problem?
Saturday, May 9th, 2009 AT 7:07 PM
BMRFIXIT
MECHANIC
Check fuses and check fuel heat sink on the fender
check for spark and ASD relay
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
SPONSORED LINKS
Saturday, May 9th, 2009 AT 8:17 PM
Please
login
or
register
to post a reply.
Related Fuel System Fuel Pump Replace/Remove Content
1988 Jeep Cherokee Bucking
1988 Jeep Cherokee 4.0 219 Thousand Miles Ok I Am Pulling My Hair Out When You Start To Drive In The Jeep It Will Buck At 10 To 15 Mph...
Asked by
Nikita1968
1 ANSWER
1988
JEEP CHEROKEE
GUIDE
Fuel Pump Replacement
When a fuel pump goes out it can do so one of two ways either it can quit and stop working or it can fail intermittently causing the engine to stall or not start.
Fuel Pump Problems
I Have Replaced 3 Fuel Pumps Since March Of 2011, Last Night The Fuel Pump Would Not Engage, So It Seems Like Its Out Again.
Asked by
BeverlyMSmith
1 IMAGE
1988
JEEP CHEROKEE
1993 Jeep Cherokee Approximate Cost To Replace A Fuel...
I Am Trying To Find Out How Much It Should Cost For Me To Replace The Fuel Pump. The Car Is Hesitant To Start Right Now And I Will Need To...
Asked by
Colin_Schroeder
1 ANSWER
1993
JEEP CHEROKEE
1998 Jeep Cherokee Changed Fuel Pump But Still...
Yesterday Out Of The Blue My Car Wont Start. Thought Maybe The Battery, Jumped The Jeep And It Would Crank But Not Start. Didn't Hear The...
Asked by
McArdleFamily
1998
JEEP CHEROKEE
1998 Jeep Cherokee Replacing Fuel Pump
Engine Performance Problem 1998 Jeep Cherokee 6 Cyl Four Wheel Drive Automatic Does An 98 Jeep Grand Cherokee Have An In Line Fuel...
Asked by
mooka5434
1 ANSWER
1998
JEEP CHEROKEE
VIEW MORE
SPONSORED LINKS
Fuel Pump Pressure Test
How to fix an engine that wont start
Engine Not Starting
Online car repair manuals
