1988 Jeep Cherokee
RLAWROW
  • 1988 JEEP CHEROKEE
  • 6 CYL
  • 4WD
  • 100,000 MILES
It just wont stop over heating. I replaced radiator, water pump, thermostate, over flow container, new electric fan. I just don't know what it is that might be causeing the promblem.
Sunday, March 30th, 2008 AT 6:56 AM
MERLIN2021
  • 17,250 POSTS
Use a radiator pressure tester, see if the leak is the intake manifold gasket. Or do a block test, about 50.00, this will tell you if there are exhaust fumes in the antifreeze. In that case probably the head or head gasket!
Sunday, March 30th, 2008 AT 6:59 AM
RLAWROW
How can I do a pressure test with no radiator cap? I can't go 2 miles without over heating or idle for 20 min. Do you think its that bad off already?
Sunday, March 30th, 2008 AT 7:07 AM
MERLIN2021
  • 17,250 POSTS
A pressure testing tool does not require a radiator cap, but if you are driving around without one, it could be your whole problem! Get a ggod I recommend a new cap!
Sunday, March 30th, 2008 AT 7:59 AM
RLAWROW
The engine never came with one
Sunday, March 30th, 2008 AT 11:52 AM
MERLIN2021
  • 17,250 POSTS
It has a cap either on the radiator, or the recovery tank.
Sunday, March 30th, 2008 AT 12:06 PM
