1986 jeep cherokee
RFAWCETT
I have a 1986 cherokee with a 2.6l. v-6, after coming home from iraq i went to drive my jeep witch has set-up in the garage since i left, the problem is i have no brakes unless i pump them at med. speed 7-12 times before they catch and then it is lousy at best, i did notice a leak between master cylinder and brake booster,but not to bad it does not want to have any brakes without babying them,but that is the only problem that i can see the brake light stays on any response would be greatful,as this is the only thing that was not taken while i was gone.
Oct 29, 2007 at 10:59 AM
2CARPRO JACK
  • 11,533 POSTS
If the master is leaking, then start by replacing that. Check pad/shoe thickness and look for leaks at the wheels as well. Probably sucked air in through the bad master cylinder and will need a good bleeding....BTW Welcome Back.. any other questions feel free to PM me
Oct 29, 2007 at 11:06 AM
