1985 Jeep Cherokee
1985 JEEP CHEROKEE
LIFTTOTHESKY
I just bough a 1985 cherokee 2.5L 4WD a couple months back. It was driving great until i noticed one day that the clutch wasn't engaging anymore. I would push the clutch pedal in all the way to the floor and there was no resistance like there should be. I would pump the pedal several times and the clutch seemed to catch after a while and engage normally. Now the problem has gotten worse and won't engage at all. It doesnt' seem to be the clutch is the problem because i can still get the car into gear and drive, but I can't get the clutch to release and move into second gear. Is there any solution on how to fix this problem or even diagnose it?
Mar 15, 2007 at 6:17 PM
DOCARCH1
[quote:6f31db0014="lifttothesky"]I just bough a 1985 cherokee 2.5L 4WD a couple months back. It was driving great until i noticed one day that the clutch wasn't engaging anymore. I would push the clutch pedal in all the way to the floor and there was no resistance like there should be. I would pump the pedal several times and the clutch seemed to catch after a while and engage normally. Now the problem has gotten worse and won't engage at all. It doesnt' seem to be the clutch is the problem because i can still get the car into gear and drive, but I can't get the clutch to release and move into second gear. Is there any solution on how to fix this problem or even diagnose it?[/quote:6f31db0014]
How does the clutch fluid look. If it has gotten too low you may now have to bleed the system & it takes a lot of bleeding. If it looks fine you may have a bad slave cylinder.
Sep 14, 2007 at 2:59 PM
