02 jeep grand cherokee 98k 4.0
ENJOI78
signal lights going crazy. with out touching the switch either the right signal or hazard light goes on. when it finally stops and i go to use one of the signal lights the hazard lights go on. i changes the relay and the switch and still does the same any help?
Feb 19, 2007 at 9:01 AM
2CARPRO JACK
  • 11,533 POSTS
Do all other lights in your Jeep work correctly? Brake, running..........
Feb 19, 2007 at 9:15 AM
ENJOI78
yup n its driving me nuts everything works fine except the signals
Feb 19, 2007 at 10:35 AM
2CARPRO JACK
  • 11,533 POSTS
When the turn signal switch was replaced do you know if the wiring in the column was checked out for chaffing or shorting?
Feb 19, 2007 at 10:54 AM
ENJOI78
i checked it myself but i gave up its at the dealer
Feb 20, 2007 at 10:30 AM
