1999 Jaguar XK8 Won't start, no diagnostics showing
88,000 MILES • V8 • 2WD • AUTOMATIC
DPROCTER
I have had no problems at all, parked it, then an hour later it would not start or even turn over. I have checked the fuses, replaced the battery, kept battery disconnected for 30 minutes, swapped out the starter relay, tried to start it in neutral.... nothing? lights, radio etc all work, but engine will not start? HELP
Thanks
Nov 10, 2010 at 2:52 PM
Just to confirm the engine is cranking but not starting. It sounds like this is the case, so we need to find out the three basic things we need to check.
First is fuel pressure, then ignition, and finally compression. You need air as well, but we can get to that if these other three check out.
Here are some guides that will need in order to figure this out.
Once we know these items we can go from there. However, we will want to pull a spark plug and hold it against the block and see if there is spark.
Lastly, is the theft light remaining on when you are trying to start the engine?
https://www.2carpros.com/articles/how-to-reset-a-security-system
Please run through all this info and let me know what you find.
Thanks
Jan 8, 2022 at 1:46 AM
