Jaguar Xjs Window Regulator On 2001 Jaguar S Type
DAVE CLEMENCE
I need to know how to replace the window regulator , can you give me instructions?
Jan 4, 2007 at 2:07 AM
DAVE H
  • 13,383 POSTS
Front Door Window Regulator and Motor
Removal
Remove the front door window glass. For additional information, refer to FRONT DOOR WINDOW GLASS.
Detach the motor and window regulator rail.
Fig. 4: Detaching Motor And Window Regulator Rail
Courtesy of JAGUAR CARS, INC.
Detach the outermost cable retaining clip.
Fig. 5: Detaching Motor And Window Regulator Rail
Disconnect the motor and window regulator electrical connector.
Fig. 6: Disconnecting Motor And Window Regulator Electrical Connector
Remove the motor and window regulator.
Installation
NOTE:Make sure that the cable from the motor is the outermost cable.
To install, reverse the removal procedure.
Attach the motor and window regulator rail.
Attach the outermost cable retaining clip.
Tighten to 6 N.m.
Fig. 7: Attaching Motor And Window Regulator Rail
Jan 5, 2010 at 8:55 PM
