jaguar 94 xjs 6cylinder 100000milies no brake pressure!
JAGUAR XJS
KUSTOMKROOM
hi guys !i bought a 94 xjs ,what happened was that i parked downhill and somehow i hit the brake pedal real hard!abs didnt work ,car stopped and i also pulled a hand brake up!so next morning i discovered that there is no brakes at all.no leaks ,oil is in a right position.and one more thing ,one night before that i almost hit a deer,and i hit the brakes real hard too,abs didnt work.after that when i was brakeing ,i can feel that driver side brake pulls more !and the handbrake light stays on,and when engine is running and i hit the pedal i can hear like switch ,,clic,, in a shift area!
Mar 2, 2006 at 12:01 PM
2CARPRO BOB
  • 45 POSTS
The “ABS” (antilock breaking systems) light will “light” when there is a malfunction in the braking system. The fault code is then stored in the computer. The computer must be scanned to retrieve these stored faults to pinpoint the malfunctioning component. Because the ABS light indicates something is wrong, a trip to you neighborhood automobile service center sooner rather than later is recommended. Your ABS system may not be functioning.
Mar 4, 2006 at 5:22 AM
