1986 Jaguar XJS engine running rich
1986 JAGUAR XJS
80,189 MILES • V12 • 2WD • AUTOMATIC
RICHM4
I've installed an used motor from florida. and when I started it ran rough and was emitting black smoke out of the exhaust. After it runs for a short time, it begins to load up and will die when you try to use the throttle. It will not start after it dies. Atfter a while it will start again, but it will do the same thing again as mentioned above. This is my first Jag. XGS. I had someone bring in a 86 Jag. to use as a guide for wiring and vaccum hoses, but there is some slight differences in the two cars. one is a XJSC whike mine is a XJS. Can you help me?
Aug 31, 2010 at 10:25 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Unplug cold start injector see if it stops loading up .if not remove cold inj. cover hole start does inj. bleed fuel.
Is fuel pressure at 36psi. ? are O2 hooked up?
Let me know
Thanks for donate
Sep 3, 2010 at 4:36 AM
