1998 Jaguar XJ8 Will not srart
89,000 MILES • V8 • 2WD • AUTOMATIC
MTOROSHANGA
Engine turns over, fuel and spark present
shows P1137 on non jaguar anilizer and' limited engine performance' on inst panel.
Feb 18, 2010 at 2:09 AM
DAVE H
  • 13,383 POSTS
P1137 O2 Sensor Heater Circuit Signal Intermittent (Bank 1 Sensor 2) .. replace the rear (after cat) 02 sensor on right hand exhaust
Feb 24, 2010 at 10:45 AM
JACK3821
It's a rare quirk on Jags, but sometimes the fuel injectors will stick open when the car is shut down and they will wash just enough gasoline on the piston rings to cause a loss of compression. The fix is simple. Remove spark plugs, inject an ounce or two of oil into each hole and then spin engine over a few turns with the plugs out. This will move the oil around until there is a seal. Replace plugs and start engine. It will smoke for a moment and then should run fine. We had to do this twice before mine would start up, it really gave us fits trying to figure out why it wouldn't start, we had fuel, we had spark, but suddenly low compression? All it was was the ring seal. Hope this helps.
Mar 31, 2010 at 7:42 AM
