1998 Jaguar XJ8 low oil pressure indicator light in red
STEVEN1906
  • 1998 JAGUAR XJ8
  • V8
  • 182,000 MILES
Greetings:
I'm getting a warning indicator light in red on my dast "low oil pressure." When I check the oil is fine and at the right level. The light seems to come on a random. No sounds are coming from the engine and no decline in performance. What could this be? And does it sound like a very expensive job to fix?
Tuesday, August 5th, 2008 AT 2:03 AM
TLEMACKS
Did you get an answer to your problem as I have the same year car with the same problem and just posted a similiar question? Thank you
Greetings:
I'm getting a warning indicator light in red on my dast "low oil pressure." When I check the oil is fine and at the right level. The light seems to come on a random. No sounds are coming from the engine and no decline in performance. What could this be? And does it sound like a very expensive job to fix?[/Quote]
Saturday, September 6th, 2008 AT 9:21 AM
