1996 Jaguar XJ6 Rear Main Seal Leak Fix
CORDREY2000
I need to replace the rear main seal due to oil leak, on 1996 jaguar xj6. my question is ,do i have to take the transmission completly out of the car to fix it, or can i just unbolt everything and just slide it back far enough to replace it?at same time i plan on replacing the front seal on the transmission just for preventative mantinence while im in there.
Mar 20, 2007 at 9:08 AM
BESTBET777
  • 89 POSTS
Check with your parts house, on some engines you can replace rear seal without pulling everything.
Apr 20, 2007 at 12:43 PM
JAMES W.
  • 2,394 POSTS
Yes, you have to pull the tranny and the flywheel to replace the rear main. It sits in a retainer that unbolts from the block. Good idea to change the tranny seal, too. I like a person who thinks ahead. Saves a lot of time and money.
Oct 5, 2008 at 4:17 PM
Suggested Repair
Remove the transmission and flywheel to replace the rear main seal, which sits in a retainer bolted to the block. Replace the transmission front seal at the same time.
Conversation Summary
The owner of a 1996 Jaguar XJ6 asked whether the transmission must be fully removed to replace a leaking rear main seal or can simply be slid back, and planned to replace the transmission front seal preventively. One reply suggested checking with a parts supplier because some engines allow seal replacement without full removal. Another expert said the transmission and flywheel must be removed and agreed that replacing the transmission seal at the same time is worthwhile.
